Post by Stinger on Nov 8, 2008 5:09:41 GMT -5
Here is the initial FAQ from our site, there is tons of good information already compiled here: www.Stinger-Performance.com/faq.htmlTHIS THREAD IS NOT FOR ASKING QUESTIONS, START YOUR OWN THREAD.
Post by 2007gtcs on Mar 20, 2009 22:05:08 GMT -5
How can i purchase the body kit that I saw on the Grabber Orange mustang I saw ?
Post by Stinger on Mar 21, 2009 15:46:06 GMT -5
What grabber orange mustang? Where did you see it?
Post by bighulk on Apr 23, 2009 16:02:21 GMT -5
how much hp does a stock 2.3t svo have?
Post by Stinger on Apr 24, 2009 1:34:53 GMT -5
175-205 depending on year. The 85.5 and 86 models were 205 and 200hp.
Post by sleepinsol on Jul 26, 2009 17:50:15 GMT -5
what sort of power numbers can i expect from an 88 t/c with a stock ihi and bolt ons. ive got a bob log, ranger roller cam, greddy fmic with 2.5" piping, ill be running a blow thru vam setup, 3" intake pipe with a k & n filter, open 3" dp, a kirban fpr to tune the fuel curve with, forge bov, and a gillis valve set at around 17-18 psi. ill be using the zeitronix zt2 wideband datalogger and im going to tune my afr to 11.5-11.8:1 at 12 * timing at the distributor or so as long as it doesnt knock. we have 93 octane fuel here in fl. i know this question is general but it may give others an idea of what to expect from their setups as well. i know the turbo will be the biggest power limiter as well. all motors are different. im just looking for a ball park range. also any criticism on this setup is welcome . **edit also posted in tech forum**
Post by Stinger on Jul 27, 2009 13:37:42 GMT -5
Post by Stinger on Feb 16, 2010 2:39:12 GMT -5
I updated the info in the FAQ page above that pertains to ecu chips and tuning and there are now links to different product offerings.
Post by turbo92 on Jan 19, 2011 20:47:53 GMT -5
can i get away with using the stock mustang clutch for a 5 speed or would i have to have the turbocoupe clutch?
Post by Stinger on Jan 20, 2011 0:05:25 GMT -5
Not if you plan to run more than 10psi.
Post by turbo92 on Jan 22, 2011 13:22:35 GMT -5
Post by Stinger on Jan 22, 2011 13:45:00 GMT -5
That's just a gasket set. A rebuild includes new rings and crank bearings and rod bearings at minimum (actually a "full" rebuild also includes new pistons and possibly rods).
With that said, I typically don't advise rebuilding a 2.3T engine as long as it is mechanically sound currently and you don't plan to make more than 375rwhp or so.
Post by turbo92 on Jan 24, 2011 21:55:19 GMT -5
where is the best place to buy a rering kit for a stock 88 tc engine?
Post by Stinger on Jan 24, 2011 23:18:46 GMT -5
Northern Auto Parts.
Post by turbo92 on Jan 28, 2011 19:53:33 GMT -5
if i buy a turbo off of a 87 merkur which is a garrett airesearch t3? will it bolt on to the stock manifold on a 88 tc
