Post by Stinger on Feb 17, 2011 0:42:51 GMT -5
As stated above:
Please try to start threads for your questions, this FAQ thread isn't intended for this.
kevinj
Post by kevinj on Mar 20, 2016 11:16:44 GMT -5
Ok so my paps told me to get on here and ask you gents a question. I have a 7mge 88 surpa n/A and I have been doing some research and what I found is that it is possible to turbo the motor, so my paps and I are trying to figure the best way of going about it. Your thoughts?
Post by Stinger on Mar 20, 2016 13:06:23 GMT -5
We don't do anything with Supra's.
Post by my87turbocoupe on May 29, 2016 3:52:36 GMT -5
My 87 tc will turn off while driving and the coil will stop Firing .. If I let it set it will start after 20 min or so ... Any ideas what's causing that Bcm ??
Post by Stinger on May 29, 2016 11:27:10 GMT -5
This thread is not for posting questions.
Your TFI is failing.
Post by vwtech86svo on Jun 17, 2016 23:14:35 GMT -5
I hope this is a correct post for this thread. Couple questions. How much power are the 4 cylinder t5 trans holding before breaking shafts or gears? And same for the 7.5 rear ends. Also I was looking at the 5.0 flywheel and bell housing adapter and was wondering if you have to use the 5.0 transmission? Or just the bellhousing bolted onto the 4 cylinder trans? From what I've read the input shafts are different diameters and slightly different lengths. The answer to the first questions really defines whether the last was worth asking.
Post by Stinger on Jun 17, 2016 23:30:52 GMT -5
425+hp if you don't miss shifts.
Maybe 250hp on the 7.5 if you're using slicks. With street tires it handles more since the tires go up in smoke before enough torque is put on the gears/axles to break.
You can use a 4 cyl trans with the adapter stuff.
Post by vwtech86svo on Jun 18, 2016 10:30:51 GMT -5
OK thank you and I apologize!
Post by 4pistonbooster on Dec 21, 2018 22:36:52 GMT -5
Hey all! So I've almost finished my 2.3 turbo swap into my '92 4wd ranger. But I'm stumped on coolant hoses. The truck has had two motors in its past (2.9l 4.0l) and it has a newer single core radiator (top passenger, lower driver) I can NOT source a radiator hose even close to fitting. I've even stooped as low as the flex hoses with no luck. Does anyone have a part number for up and more importantly the lower hose?
Post by Stinger on Dec 21, 2018 22:46:21 GMT -5
This thread is not for asking questions.
Without knowing what radiator is on it it's impossible to say what hoses it needs. With that said, 92 Rangers were offered with 2.3's in them so the stock hoses for that application and a 2.3 ranger radiator is a direct fit.
Post by 4pistonbooster on Dec 21, 2018 22:58:18 GMT -5
This thread is not for asking questions. Without knowing what radiator is on it it's impossible to say what hoses it needs. With that said, 92 Rangers were offered with 2.3's in them so the stock hoses for that application and a 2.3 ranger radiator is a direct fit. Hey my bad just realized its titles FREQUENTLY ASKED QUESTIONS because of the very first post. Sorry! But thank you for the quick reply!
