Post by denz on Jul 21, 2010 23:41:59 GMT -5
Just installed my AC and wanted to know what i should do with my timing. I have my map set to your timing map from your site. Will this work when it comes on or does it need advance. I will be making the trip to Matts and want to get the best mile per gallon I can.
Post by Stinger on Jul 22, 2010 0:02:18 GMT -5
You shouldn't need to change the timing for the a/c and the small amount of load it puts on the engine. It's got 35+ degrees during cruise which is about the same as an LA3.
