Post by Stinger on Aug 5, 2010 23:13:16 GMT -5
dizzle
Post by dizzle on Aug 7, 2010 6:39:32 GMT -5
I down loaded link. It gives me three options; Modify existing driver, Repair existing driver, Erase existing driver . I have tried all three and still am not able to connect with the MS (after deleting, i reinstalled driver).
Post by Stinger on Aug 7, 2010 11:28:55 GMT -5
And the "!" remained throughout all the installs when viewing in the device manager? I'm asking because not being able to communicate with the MS isn't a valid test of a working driver.
Post by Stinger on Aug 7, 2010 11:29:24 GMT -5
Also, is your USB cable silver with clear blue ends?
dizzle
Post by dizzle on Aug 7, 2010 12:54:28 GMT -5
It is clear with green ends. In side the cable looks like braided fuel line, if that helps.
Post by Stinger on Aug 7, 2010 17:46:19 GMT -5
Sounds like the prolific cable which uses that driver posted above.
dizzle
Post by dizzle on Aug 9, 2010 19:25:14 GMT -5
And the "!" remained throughout all the installs when viewing in the device manager? I'm asking because not being able to communicate with the MS isn't a valid test of a working driver. Sorry for the delayed response. Yes the "!" is still there through all of this. What other options do you think i schould try.
Post by Stinger on Aug 10, 2010 2:19:00 GMT -5
The best option would be if you have someone that has an above average knowledge with computers. I think I could get it working within 30 minutes if I had it sitting in front of me.
Otherwise I'm running out of suggestions as you've done everything it should take to get it working. It's probably just something small that's screwing it up.
dizzle
Post by dizzle on Aug 10, 2010 18:18:48 GMT -5
Just for Shidzz and giggles, could you video your self going step by step, starting at the very beginning. Down loading the driver and every thing that i would need to do on my end. If that doesn't work ( me copying what you do), I will take my computer to Best Buy and talk to the Geek Squad. I'm afraid they are going to try to gig me though. . . . Or i could fly up there and challenge you to your 30 min fix.
Post by Stinger on Aug 10, 2010 22:45:45 GMT -5
Unfortunately I don't think I can do that. Geek Squad may be the best bet, they should be able to figure it out.
dizzle
Post by dizzle on Aug 11, 2010 20:12:20 GMT -5
As always, Thanks for all your help. It is much appreciated!
Post by Stinger on Aug 11, 2010 21:35:08 GMT -5
Be sure to have them tell you what com port it is setup on once they get it working!
dizzle
Post by dizzle on Aug 16, 2010 19:07:31 GMT -5
I'll do it. Thank you .
dizzle
Post by dizzle on Dec 21, 2010 9:57:38 GMT -5
Finally got it working. Now starts the fun stuff!
Post by Stinger on Dec 21, 2010 15:39:44 GMT -5
What did you have to do to get it working?
