Post by reaper5lm on Dec 29, 2008 11:56:30 GMT -5
?? When You change the rear end on a 88 Thunder Bird and you put it on the Mustang it's a 1/2"-3/4"Difference. I Replaced the axles with Mustang Length Axles 31 Spline. Now it should be back to Normal right?
Post by Stinger on Dec 30, 2008 4:24:07 GMT -5
TC Rear is 3/4" wider because of the ABS rings on the axles, stock length Mustang axles should make it a "Mustang" rear again.
Post by reaper5lm on Dec 30, 2008 7:49:07 GMT -5
That's what I thought. I need to check the backspacing on the draglights. I am having tire rub on the outside Rear . I'll need to roll the outer fenders. Or more air in the bags.
Thanks
Post by Stinger on Dec 30, 2008 14:18:49 GMT -5
You should have good luck with 5.5 backspacing, that's what we run with tires as large as 28x10.50's. The lip is rolled though. 4.5 backspacing should work with 26x8.50's.
Post by reddragon777 on Dec 30, 2008 14:44:20 GMT -5
yeah i have 4.5 beackspacing on the 06 and it sucks when it comes to deep tires in the back.
Post by reaper5lm on Dec 30, 2008 14:51:01 GMT -5
I am running the 28x10.50's and it rubs on a hard bumb or hard launch. I'll roll the lip to fix the problem. I should have done this before the paint..#@%$
Post by Matt Culpepper 2300gearjammer on Jan 18, 2009 11:50:33 GMT -5
What did you do for brakes? and are they still c-clip axles?
Post by reaper5lm on Jan 20, 2009 21:14:04 GMT -5
I am running the ones that come on the T-bird (disk) with new calipers/pads. Yes, c-clip 31 spline axles with carbon fiber clutch kit.
Post by Matt Culpepper 2300gearjammer on Jan 25, 2009 0:12:55 GMT -5
ok because i was really confused how the hell you would be able to get the c-clip back in if using a mustang length with TC brakes. The c-clip rear requires an adaptor for the calipers.
You sound good to go though and should have and impossible to break rear.
Post by reaper5lm on Jan 26, 2009 15:59:15 GMT -5
I should, Now I Have to upgrade the Trans. I like the T-5 But It could be my cars weakness.
Post by Matt Culpepper 2300gearjammer on Jan 26, 2009 21:29:05 GMT -5
whoa I read your reply to my post completely wrong. You still have a C-clips. I'm back to a little intrigued. I dont understand how it fits without changing the offset of the caliper bracket. Those axles should sit in just enough that when you put the rotors and wheels on, the rotor should hit the bracket?
Edit: T5 limit?
Whats your build?
Post by Stinger on Jan 27, 2009 1:31:18 GMT -5
Matt, this is the azure blue notch that I tuned...400ish hp.
Post by reaper5lm on Jan 27, 2009 20:46:29 GMT -5
I just asked my buddy from the shop that got me the axles. Yea, they are 31in+ in or so longer than stock. *#@! I didn't even Know. Well it doesn't matter now looks like the car is almost sold. I'll find out by the end of the week.
Post by Matt Culpepper 2300gearjammer on Jan 28, 2009 21:09:46 GMT -5
ahhh gotcha...and...ahhh gotcha lol
