Post by Matt Culpepper 2300gearjammer on May 16, 2011 21:57:15 GMT -5
I'm shooting for hitting the track before the end of June. I have a ton of sorting out on the clutch, chassis and tune so even once its running it'll be a while before I try to knock out any kind of good ET.
dizzle
Post by dizzle on May 21, 2011 11:40:41 GMT -5
Just out of curiosity, are you going to paint the k- member and steering rack?
Post by Matt Culpepper 2300gearjammer on May 22, 2011 23:44:10 GMT -5
The Kmember and suspension is powder coated and when cleaned off looks fine. The steering rack will get dumped for a flaming river or equivalent.
dizzle
Post by dizzle on May 23, 2011 16:23:28 GMT -5
Have you ever drove a car with a flaming river rack? The reason I ask is I would like to know if it turns easier than a manual set up in a 67ish model mustang.
Post by 75pinto on May 23, 2011 16:32:30 GMT -5
i am extremely disappointed that it isnt running and ripping off low 10's yet
Post by Stinger on May 23, 2011 18:32:38 GMT -5
Have you ever drove a car with a flaming river rack? The reason I ask is I would like to know if it turns easier than a manual set up in a 67ish model mustang. I wouldn't count on it...the steering ratio is much different between the two setups and the 67 steering wheel is quite a bit larger (more leverage). The 67 should be much easier to steer.
Post by Matt Culpepper 2300gearjammer on May 26, 2011 7:08:31 GMT -5
Post by bobbarker on May 26, 2011 7:17:38 GMT -5
LOVE that crossmember!
Post by Matt Culpepper 2300gearjammer on May 26, 2011 8:19:31 GMT -5
Ha is that sarcasm because I wasnt too sure about the crossmember. lol I put the trans where I wanted and whipped it up. When I do things like that I'm never happy with how they turn out.
Post by bobbarker on May 26, 2011 12:55:44 GMT -5
No I'm serious! It's HUGE and shiney, and seems to be functional! Would make a great conversation at the track too.
dizzle
Post by dizzle on May 26, 2011 16:10:32 GMT -5
WICKED BAD A$$ !!!!!!! It is coming along nicely! I can't wait to see some videos of it when its done. Don't forget to put the finished pics in the "cleanest engine compartment" thread. Mr. Barker is absolutely correct, the cross member looks good.
Post by Matt Culpepper 2300gearjammer on May 26, 2011 21:02:24 GMT -5
Thanks guys. I know that thing looks big and bulky but it amazingly close to a stock cross member and lighter than a TC one. Its made from an extra chunk of the 1 5/8" bars I had for the cage.
venom455
Boosting 10 psi
Performance Suspension Components
Post by venom455 on May 30, 2011 21:28:42 GMT -5
I couldn't find it so I was just wonder what is your radiator and intercooler out of/for? Thanks looking good.!
Post by 75pinto on May 30, 2011 21:44:20 GMT -5
intercooler is a large NPR and the radiator is a b-cool (i believe)
Post by Matt Culpepper 2300gearjammer on May 30, 2011 23:13:46 GMT -5
Yeah I believe the part number is 65005 Be-cool rad.
I'm working on gathering all the part numbers for every single system I've been working on. That way when its all done I can report exactly what worked (or broke.)
