craigb
Post by craigb on Nov 11, 2009 19:00:06 GMT -5
That's with the spout in (well out to set it, then plugged back in after I was done). But like I said, I don't trust the timing light or the timing marks, that's just where it ran the best.
Post by Stinger on Nov 11, 2009 23:47:34 GMT -5
So it reads 20 degrees after you put the spout in (at idle) or you are measuring the total advance at WOT somehow?
craigb
Post by craigb on Nov 12, 2009 11:52:11 GMT -5
It's reading 20 with the spout out, then I plug it back in. I've never thought to check it with the spout back in. I don't have a way to check total timing at WOT.
Post by Stinger on Nov 12, 2009 15:42:24 GMT -5
I'd definitely say your timing marks aren't accurate then if that's the case!
Post by denz on Nov 12, 2009 17:26:47 GMT -5
right because it would be closer to 30 with spout in right?
craigb
Post by craigb on Nov 12, 2009 17:42:11 GMT -5
The numbers are all rubbed off. The lines are still there. What's the notch, 10* or TDC?
Post by Stinger on Nov 12, 2009 23:29:32 GMT -5
Notch is TDC and each mark is 2 degrees.
craigb
Post by craigb on Nov 13, 2009 0:35:33 GMT -5
Hmm, I'll have to check it again then. I'd really like to get one of those MC Machine billet timing pointer, that would take the pointer out of the equation.
