Post by 2.3T Fan on Jun 21, 2011 8:30:22 GMT -5
I have a 91 LX with a 2.3T Swap..
Car has T3, FMIC, 3" DownPipe to Midpipe, 3" Cat, 2.5" Muffler to Tail..
I wanna turn the boost up, can I SAFELY go up to 23PSI on the Turbo??
How much is the 2.5" Muffler n TailPipe gonna hold me back from a Full 3" or Dual 2.5"??
Will I be able to get 270ish at the wheels?? Any Idea on what it would run in a 1/4 Mile with Sticky Tires (DragRadials or ET Streets)??
Post by Stinger on Jun 21, 2011 10:22:03 GMT -5
You most likely won't be able to run 23psi on pump gas.
Tailpipe restriction depends on how much hp you are making (which is unknown).
With the parts listed you probably won't make 270rwhp. Insufficient info to say what it would run at the track. Way too many variables. Much easier to just take it to the track and see.
Post by 93lxturbo on Jun 21, 2011 14:37:16 GMT -5
i have a 93 lx and this is whats done to it, stinger center mount header, fmic and 3" exhaust, bobs gutted upper, ported/knifed lower, 65mm tb, kirban fpr , walboro 255, la3 and brown tops
on 20lb the timing at 14 and street tires it ran a 8.6 at 83mph
Post by 2.3T Fan on Jun 21, 2011 18:50:39 GMT -5
i have a 93 lx and this is whats done to it, stinger center mount header, fmic and 3" exhaust, bobs gutted upper, ported/knifed lower, 65mm tb, kirban fpr , walboro 255, la3 and brown tops on 20lb the timing at 14 and street tires it ran a 8.6 at 83mph Brown Tops r the Stock SVO Injectors, Right?? I was lookin for 1/4 Mile, I dont have Header, Intake Work, or Bigger TB.. What is the TB off of?? Will the 94/95 5.0 Mustang TB Bolt on?? What would 250RWHP with Slicks get me in a 1/4 Mile?? "Above setup plus cone filter, 3" exhaust, 15-20psi will produce roughly 200-245rwhp."
Post by Stinger on Jun 21, 2011 19:02:49 GMT -5
Use an online calculator to see what it will run if everything is perfect (meaning if you're a pro driver, suspension is setup perfect, launch rpm is perfect, etc.). www.wallaceracing.com/Calculators.htm
Post by 93lxturbo on Jun 22, 2011 5:48:52 GMT -5
I thank the car has around about 320rwhp on a 100 or 75 shot, and if I can get everything right at the track I thank I can run a 11.999 maybe, but should pull 12.3 to 12.5 until I'm out of spray and the speed should be around 110 to 115, I'm wanting the 115 I can take down a gt500 and that's around about what they run
As for the brown tops they do come In svo, I got mine out of the thunderbird, the tb if I'm right has to be made to fix or order the adapter plate,
