dizzle
Post by dizzle on Jul 7, 2011 14:00:30 GMT -5
Is it possible to add rows and columns ( to Ve and timing) in tunner studios? The reason I ask is I would like to lower the gap between the values in each. I don't know if this would even be beneficial but it sounds like a good idea to me.
Post by Stinger on Jul 11, 2011 15:41:04 GMT -5
No, you can't add them. You can change their values to concentrate more cells in an area you're having trouble with but you'll need to space them out farther elsewhere.
Keep in mind the ecu doesn't just use the value in the cell, it uses the average of the cell it's currently running on, as well as the surrounding cells to find the value to command. This cell averaging makes the gap between cells virtually non-existent from a tune standpoint.
dizzle
Post by dizzle on Jul 11, 2011 15:52:32 GMT -5
Thank you much!
