craigb
Post by craigb on Oct 9, 2011 21:55:26 GMT -5
Post by bobbarker on Oct 10, 2011 4:37:24 GMT -5
gas sitting for a couple years should be the problem!
Good luck with your project, sounds like you've got a bit of work ahead of you.
Post by Stinger on Oct 10, 2011 12:19:18 GMT -5
It's no SVO but it looks like a good place to start. Definitely a good idea to get the TC running before swapping the drivetrain.
craigb
Post by craigb on Oct 11, 2011 10:17:42 GMT -5
I'd really like to find an SVO front end to put on the coupe, but the parts for those are so pricey...
craigb
Post by craigb on Oct 12, 2011 21:41:05 GMT -5
Started working on the T-bird tonight. I'm trying to get it running before I pull the engine, but it won't start.
Here's what I found:
Cranks no problem There is spark Fuel pressure shows 0 at both shrader valves Fuel pump will run on 12 volts, but I can't build pressure on the gauge Fuel pump receives 9.9 volts only when cranking No voltage to pump with key in on position Fuel will come out of filter while cranking
Something I just thought of, I have to use a screwdriver to start it. I wonder if there is a problem with the electrical ignition switch...
Any other ideas?
Post by Stinger on Oct 12, 2011 23:55:21 GMT -5
Are you sure the gauge is opening the schrader valve? I find this to be a common problem as the center of the valve is lower than normal and the gauge doesn't press it. I have to remove the center of the valve to read fuel pressure.
craigb
Post by craigb on Oct 13, 2011 0:22:54 GMT -5
I can give that a shot. Might take the fuel damper off while I'm at it.
Post by Stinger on Oct 13, 2011 0:45:59 GMT -5
It's just very odd to have fuel flow but no pressure at all. That's why I'd suspect the problem mentioned above first.
craigb
Post by craigb on Oct 13, 2011 11:36:14 GMT -5
What if the pump is weak?
craigb
Post by craigb on Oct 16, 2011 10:22:40 GMT -5
Pulled the schrader valve out of the fuel line. Hooked a 12v 1a charger up to the pump and fuel will come out, but it's more of a trickle than what I would expect.
craigb
Post by craigb on Oct 16, 2011 21:47:04 GMT -5
Dropped the tank and pulled the pump. The hose that runs from the pump to the pump bracket was soft, like jello. It was split too. So, I'll replace that, put it all back together and see if she fires.
Post by Stinger on Oct 16, 2011 22:26:47 GMT -5
That will probably do it. If it's soft, it's most likely swelled nearly shut internally.
craigb
Post by craigb on Oct 17, 2011 18:06:40 GMT -5
Post by bobbarker on Oct 17, 2011 19:47:12 GMT -5
That'sa good feeling to get it moving, huh?
craigb
Post by craigb on Oct 17, 2011 21:08:12 GMT -5
Indeed. No power and no brakes though. I did find the #4 plug wire was disconnected, but it wouldn't make any boost.
