Post by slumlord on Apr 1, 2021 6:48:13 GMT -5
Just a quick follow up for anyone else considering the 11-900, I contacted Canton about these baffles and this is the response.
We only offer circle track oil pans for the 2.3L. These won't work in autocross applications. Thank you for contacting Canton, -Iann Canton Racing Products
Post by Stinger on Apr 1, 2021 13:04:39 GMT -5
I wonder what the reason is for that? Maybe the way the baffles are set up it's only good for turning left?
max7
Post by max7 on Aug 13, 2022 16:10:02 GMT -5
As a follow up the Canton oil pan turned out to be a nightmare and I would steer clear of it on a SVO. The pan is designed for the later 2.3 with the smaller main journals. Also it will hit the stock k member. You wil not be able to attach your clutch cable in the stock position on the bell housing. In short unless you are willing to make major modifications steer clear of this unit.
flhotrod
Boosting 10 psi
Member is Online
Post by flhotrod on Aug 13, 2022 18:06:42 GMT -5
Post by Stinger on Aug 14, 2022 21:57:32 GMT -5
Thanks for the link.
