Post by stangman93 on Mar 24, 2012 13:27:07 GMT -5
New over here and thought I would share some vids. A lot of ya'll may have seen them over on TF. I have had a blast working on the build the last several years.
on the dyno yesterday, made 470rwhp at 22psi.
testing at the track, much to learn
first full pass, low boost
test pass from the stands
becools
Addicted to boost..
Post by becools on Mar 25, 2012 9:06:14 GMT -5
Sweet man, sounds good..
Post by bobbarker on Mar 26, 2012 18:58:57 GMT -5
sounds fast!
I know a lot of people from SA. I used to live there. Do you get on LSS.com?
Post by stangman93 on Mar 27, 2012 12:08:23 GMT -5
I just have been surfing around on LSS.com lately.
Here is the third run from Saturday night. I have to get this suspension lined out so this stops happening. lol
Post by bobbarker on Mar 27, 2012 13:28:16 GMT -5
There are (if you haven't found out yet) at least four 2.3T stangs on LSS that post regularly in the "money pit" projects section.
Post by stangman93 on Apr 25, 2012 19:08:35 GMT -5
Here is the latest vid after some suspension work. First run was run on the same tuneup as the last video above and it bogged. Raised the launch rpm 300 and the car left much stronger without much bog. It did go rich and lay over in 1st so I shifted out of 1st about 700 rpm early.
Here is the vid of both test runs.
