Post by 2.3T Fan on Nov 10, 2008 17:57:31 GMT -5
Are there any Differences From a 84 SVO to a 86 SVO?? Power, n Turbo the Same??
Also, What are the 2 switches under the Radio 1 Fog Lites, other??? Next to the Timer??
Post by chemicalexcuse on Nov 10, 2008 19:30:19 GMT -5
my svo had 2 switches on for amplifier and one for fuel grade
Post by svojohn on Nov 10, 2008 20:43:20 GMT -5
The 85' and 86' SVO's used fog lights for one switch and Premium/Regular fuel for the other switch.
I think the 84' SVO was the only year that used the amplifier switch.
Post by chemicalexcuse on Nov 10, 2008 20:53:56 GMT -5
mine was an 84
oh and 2.3tfan the early 84's had traction bars and in late 84-86 had quad shocks..the 84's made less power than the 85.5 and 86....
Post by Stinger on Nov 10, 2008 22:15:38 GMT -5
Ecu is different for the 85.5-86 SVO's as well. Turbo is a T3 on all of them. Late cars (85.5-86) also got dual exhaust. I believe the early SVO's also had 30lb injectors while the late cars had 35's.
Post by chemicalexcuse on Nov 10, 2008 23:02:06 GMT -5
did all svo's come with large vams? i mean if it came with 30lbs injectors would'nt it use a small vam?
on a side note is it true the svo ecu's run at 7.5 hz or something and the la3 runs at 12 hz and thats why the la3 idles better and stuff? i'm not ecu literate but does that mean the la3 is a "faster" processor...or does the la3 just have different timing maps...too many beers haha
Post by Stinger on Nov 10, 2008 23:19:23 GMT -5
The L series ECU's are a more advanced processor and are "faster" as you put it. They all had the big vam, even the early cars with 30lb injectors.
The 85+ SVO's also got dark grey trim rather than black and an optional 3rd brake light in the wing. The very early 84's and 85.5+ also got the SVO decals on the fenders. The 84's had piping on the seats and the other years didn't and also got the "regular" T5 with the 4.03 first and .86 OD. The rest of the SVO's got the 3.50 first and .78 OD gear. 84's also got 3.45 rear gears while the rest of the cars got 3.73's.
schlot
Post by schlot on Nov 24, 2008 15:23:33 GMT -5
Most of the differences have been covered so far. But here are a couple more.
'84 and '85 have the smaller cam (0.390") vs. the 85.5 and 86 larger cam (0.400") lift. Also, the '84 had an "inline" intake vs. the "square" intake of the later models.
Also the later years have a A/R ratio on the turbo of 0.48 vs. the earlier 0.63, were water and oil cooled vs. the early models relying on only oil cooling.
The faster processor is prob. why the LA3 idles better, but it is from a TC and it requires a different wiring setup. The PE computers from the later SVOs are a plug in system and are nearly as good. The LA2 is almost the same as the LA3 at less money.
The 86 had a brake light incorporated into the spoiler.
Like Stinger said, the T5's were "world class" in the '85 and up models. Also the diff ratio in the '84 was 3.45 vs. 3.75 in the later ones.
'84 SVO's had different valving in the front struts, which was a pretty minor change.
