Post by mroyal87 on Oct 10, 2012 19:34:07 GMT -5
Looking for the u shaped linkage that connects the big clutch cable to the lever that pulls the small cable. Any one have one?
Post by ben12178 on Oct 11, 2012 20:05:06 GMT -5
Ford dealer can get it. If I remember right it was maybe $6. The part cross references to a 75 pinto parking brake cable connector I do believe
Post by ben12178 on Oct 11, 2012 20:10:17 GMT -5
If the other part like it is still good you could switch it and make a piece of linkage with threaded rod bent 90 degrees with washers and nuts on the ends. Its what I did while I waited for the part to come in
Post by mroyal87 on Oct 12, 2012 7:56:16 GMT -5
thanks man
Post by ben12178 on Oct 12, 2012 22:31:03 GMT -5
no problem
