X-RAT
Boosting 15 psi
Post by X-RAT on Apr 4, 2009 13:49:19 GMT -5
I have a 1988 Merkur XR4Ti thats automatic C3 Transmission with a PK1 computer in it. Can i simply install a LA3 with the Large VAM with the transmission I have now?
Post by Stinger on Apr 4, 2009 18:42:38 GMT -5
Yes, if you repin your harness for the LA3.
Post by Merkur on Apr 8, 2009 17:29:48 GMT -5
What do you mean Re-pin? Take my PK1 out and put the correct pins on the LA3 like for the 5spd ?
Post by Stinger on Apr 9, 2009 1:50:23 GMT -5
The wires that go into the ecu for each function or sensor are in different places for around 10 of the wires. This means you need to pull those wires/pins out of the ecu plug and move them to the correct locations. Wiring details are here: rothfam.com/svo/reference/PEtoLA.pdf
