Post by menewel0 on Jul 16, 2013 14:22:12 GMT -5
Was planning on assembling a ms2 with v3 board for the Merkur. Would the assembly be the same as my 91 mustang with a 302. The 302 is bank fired. Should I bank fire the 2.3 or run sequential?
Post by Stinger on Jul 16, 2013 15:28:17 GMT -5
Stock 2.3's are batch fired so it should be fine going that route. If you're going to run huge injectors (95+lb) you may benefit from sequential.
Post by menewel0 on Jul 16, 2013 18:37:34 GMT -5
Thanks for the info. I will be running hi impedance 56lb injectors so I think I will be alright bank fired.
