Post by n01290087 on Mar 12, 2014 20:50:34 GMT -5
1988 turbocoupe. It was my first car but has frame rot unfortunately. Good running stock motor, smooth transmission, good rear end on it. The doors are rust free and the front bumper is intact. The bumper is not ripping off the lower part. I can not part the car (have to keep it at parents house after restoration shop said to come pick it up it was more than they thought it was worth doing). Tan interior in decent shape. I'd like 750 since it's a complete car with good driveline and parts. Open to offers since I unfortunately have to get rid of it or find a shell to transplant into mine.
Post by filasfinest86 on Mar 14, 2014 22:53:51 GMT -5
Where you at my man? I've saved numerous 80's fords by plating frames with (HSS) high strength steal its a common occurance on these fords to rot in the shock tower.. IDE recommend a second opinion as long as there it some meat there and the front end hasn't shifted it can be repaired IMO.. I'll try and post some pics of some jobs I've done..
Pic 1 before Pic 2 after sandblast and epoxy primer applied Pic 3 inner structure of frame rail plated with a 1/16 inch heavy duty metal ... Tubes were inserted to prevent smashing of frame pocket when crossmember bolts are tightened(factory has these usually gone from rust...
Post by filasfinest86 on Mar 14, 2014 23:19:00 GMT -5
After all the fab work and finally the candy red to top it off stronger than factory I guarantee it..
Post by n01290087 on Mar 15, 2014 16:24:14 GMT -5
That work looks amazing. The issue is the rear also has issues in trunk area apparently where the shocks are. I'm trying to find a shell. I don't think its that bad and I was going to just change the whole front to a mustang frame and m and m kmember, lower control arms and switch to coil over. So basically from the fire wall forward was going to be replaced
Post by filasfinest86 on Mar 15, 2014 16:39:42 GMT -5
Yep yep sounds like a plan man thanks
Post by n01290087 on Mar 15, 2014 18:14:44 GMT -5
Where are you located?
nmsvl
Boosting 10 psi
Post by nmsvl on Mar 20, 2014 20:28:53 GMT -5
How much for the turbo with oil and coolant lines
Post by n01290087 on Mar 21, 2014 10:08:19 GMT -5
It's for parts not being parted out, you would have to take whole car
Post by itchyturtle1981 on Apr 1, 2014 22:53:01 GMT -5
where are you located
Post by n01290087 on Apr 2, 2014 18:20:10 GMT -5
Ny 60 miles north of nyc
Post by filasfinest86 on May 5, 2014 23:20:26 GMT -5
Located in central IL
Post by xlspilot on Jun 5, 2014 11:51:50 GMT -5
Post by xlspilot on Jun 5, 2014 11:52:12 GMT -5
Where is your Tbird located?
