jet1
afr
May 20, 2009 15:57:00 GMT -5
Post by jet1 on May 20, 2009 15:57:00 GMT -5
What is my ideal afr target through a map when starting to go into boost. At idle I am 14.5 as I eccelerate and start getting into boost do i want to gradually start going richer to the point when where i am at max throttle i see 11 or see 11 at all boost?
afr
May 20, 2009 17:29:08 GMT -5
Post by Stinger on May 20, 2009 17:29:08 GMT -5
At wide open throttle you want 11.5-12.0 throughout boost. Under cruise and light throttle conditions where it may build a few psi going up a hill or something, it is ok to let it be 13-13.5 under 5psi to save fuel.
jet1
afr
May 23, 2009 21:27:06 GMT -5
Post by jet1 on May 23, 2009 21:27:06 GMT -5
Ah, THanks
