Post by turboe85ford on Apr 1, 2014 11:11:56 GMT -5
the motor ran great for years. Recently I decided to go a different route with my car.
The engine has the following: -diamond .30 over 8:1 comp forged pistons
-ported cast iron head with roller rockers and stage 2 boport race cam over sized valves
-Agp Turbonetics ball bearing t3/t4 .48 a/r turbo with polished housing. Custom mount elbow to retain factory ported exhaust manifold
-accel 55 lb fuel injectors Front mount intercooler with pipes
-centerforce dual friction clutch
**Ecu and wiring harness will not be included**
-the motor ran before I pulled the motor out. The turbo is I'm good shape but they .48 exhaust housing is cracked, .48 is too small anyway upgrade to a .63. The head gasket is on it's way out and needs to be replaced. The motor could be inspected but seemed fine. I paid 900 just for the turbo I'm asking $1000 pick up only for everything. Car made 332 rwhp 378 rwtq 25lbs of boost on 110 race fuel.
Call/text 8102787710 or email wilson_deny@yahoo.com located north of Detroit Michigan.
