Post by Stinger on Jul 31, 2014 1:43:53 GMT -5
Fire Extinguisher Mounts - Fox Body Mustang, Capri, and ThunderbirdSimple to install fire extinguisher mounts for 79-93 Mustang, 80's Capri, and 83-88 Thunderbird. Mounts bottle behind either front seat and tucks up close to the seat to retain rear passenger foot space while still being close enough to driver to quickly and easily use if necessary. Mounting platform is pre-drilled for use with H3R Performance 2.5lb bottle (not included). These are available from Summit and Jegs. Part Number MX250B (black). Bottles also available in red and chrome. -Simple and space efficient design -All hand made steel construction -Durable high gloss black powdercoat finish -Only requires a 10mm wrench to install on your driver's or passenger's side seat -Bolts directly under seat in existing factory drilled holes -Comes complete with mounting hardware for extinguisher and mount -Allows for quick one-handed operation of extinguisher -Compatible with many popular fire extinguisher bottles from 1lb to 2.5lb size -100% USA Made Price: $ 40.00 Shipped
Post by JW on Jun 10, 2017 16:34:41 GMT -5
I would like to buy one how can i and how fast can it be shipped to ohio thanks
Post by Stinger on Jun 10, 2017 21:50:22 GMT -5
Post by Giovanni Lauriano on Jun 16, 2022 8:17:41 GMT -5
Where do you get the holder for the fire extinguisher itself tho.that mounts to that mount
Post by Stinger on Jun 16, 2022 9:50:15 GMT -5
