Post by scooter1112 on Sept 15, 2014 18:09:15 GMT -5
I had done my swap a few years ago and can't figure out what connector goes to the temp senso and I have an extra connector that doesn't fit anything please Help want to get her running
Post by Stinger on Sept 15, 2014 22:44:56 GMT -5
You'll need to be much more specific than that. What is the vehicle you swapped into? What did the engine come out of? Do you have a pic of the connector that doesn't fit anything?
Post by scooter1112 on Sept 16, 2014 5:11:40 GMT -5
Motor came out of a 85 t bird swapped into a 90 mustang. I do have a picture but don't know how to post it on here
Post by Stinger on Sept 16, 2014 13:16:28 GMT -5
You'd need to host the photo somewhere like photobucket and then post the link here. You can email it to us if that's easier for you.
Post by scooter1112 on Sept 17, 2014 11:31:38 GMT -5
Post by scooter1112 on Sept 17, 2014 11:33:46 GMT -5
I have the air temp sensor hooked up
Post by Stinger on Sept 17, 2014 12:08:17 GMT -5
That's the coolant temp sensor. The injector harness contains the wiring/connector to plug into this sensor.
Post by scooter1112 on Sept 18, 2014 17:16:27 GMT -5
My harness doesn't have that plug with the injector harness and the coolant sensor is 2 wire connector and the connector is 3 wire
Post by Stinger on Sept 18, 2014 17:31:33 GMT -5
Which injector harness are you using? What intake are you using (TC or Mustang)?
Post by scooter1112 on Sept 18, 2014 17:39:29 GMT -5
Post by scooter1112 on Sept 18, 2014 17:42:10 GMT -5
That's the pic of the harness I'm using the turbo coupe intake and Mustang injector harness
Post by Stinger on Sept 18, 2014 21:32:25 GMT -5
What's that big bulge in the middle of the injector harness right where the coolant sensor wires would normally come out? There is a ball of grey stuff, as well as a bulge under the harness tape. Looks like it's been modified. If you still have the TC injector harness, or the Mustang intake manifold, compare them to what you're using. You should find the coolant sensor in the same location in the Mustang intake.
Post by scooter1112 on Sept 19, 2014 7:56:25 GMT -5
Post by scooter1112 on Sept 19, 2014 8:01:05 GMT -5
Not really sure what the bulge is I will have to look at it tonight.
Post by scooter1112 on Sept 19, 2014 8:03:18 GMT -5
I think I have the injector harness still for the turbo coupe but I don't have the Mustang motor anymore
