Post by scooter1112 on Sept 20, 2014 14:15:49 GMT -5
I looked at that bulge in the wiring and it looks all factory to me. Just stumped And want to get her running. Thought about tracing the wire from the main computer to the connector.
Post by Stinger on Sept 20, 2014 14:57:50 GMT -5
There is nothing factory about that bulge. Tracing wires may be your only option since what's stock is the wires you need coming out of the injector harness and obviously you don't have that so you've got something that's "not normal".
Post by scooter1112 on Sept 21, 2014 16:28:08 GMT -5
Post by Stinger on Sept 21, 2014 19:57:18 GMT -5
Weird
Post by scooter1112 on Sept 22, 2014 18:03:01 GMT -5
Yup now you see why I'm getting frustrated. The wire from the computer goes to the connector for the fuel injector harness. Thinking about running a wire to the sensor with a new plug
Post by Stinger on Sept 22, 2014 18:23:13 GMT -5
That just reinforces that the connector for that sensor "should" be in the injector harness. For some reason you just have a weird injector harness. If you still had the Mustang injector harness, it would have the wiring you need. Certainly nothing wrong with buying a connector for the ECT and running the wires to it.
Post by scooter1112 on Sept 24, 2014 18:25:14 GMT -5
Post by Stinger on Sept 24, 2014 21:47:18 GMT -5
Looks like it's supposed to now!
Got any pics of the FMIC pipe/turbo situation?
Post by scooter1112 on Sept 25, 2014 8:18:56 GMT -5
Just want to say thanks for all your help and I will post pictures as soon as I can.
Post by scooter1112 on Sept 28, 2014 19:32:16 GMT -5
Post by Stinger on Sept 28, 2014 21:55:01 GMT -5
Hmm, never seen that. What turbo? Are you using a spacer between the header and turbo?
Post by scooter1112 on Sept 29, 2014 13:34:16 GMT -5
I thought about putting a spacer in the intake. You its about 3/4 thick to clear valve cover and it's a h1e turbo.
Post by Stinger on Sept 29, 2014 22:11:52 GMT -5
Is there a spacer on the header or not?
Post by scooter1112 on Sept 30, 2014 18:39:05 GMT -5
Yes there is about 3/4 think
Post by scooter1112 on Sept 30, 2014 18:39:54 GMT -5
Thick
