Post by wesk on Sept 25, 2014 15:06:32 GMT -5
These have been discussed on this forum, TF, and TF Facebook.
Basically this is a retrofit kit to turn the 2.3t TFI distributor into a 16-1 Cam angle sensor. This allows you to run sequential fuel and spark with a single sensor, and retains the functionality of "killing" the engine if the aux gear strips (instead of continuing to run with no oil pressure).
Pricing is 180$ shipped with a Deutch DT 3 pin connector terminated to the sensor, and crimp pins/shell to make a mating connector. If you don't have an adequate crimp tool, and want me to assemble this connector as a flying lead pigtail, this will be an extra 10$.
Please PM me for the "first draft" of instructions to get an idea what you are in for.
Post by jahlive12 on Feb 7, 2015 12:54:28 GMT -5
Hello Wessk, Do you know when you will be running another batch of these
Post by wesk on Feb 9, 2015 13:26:18 GMT -5
Still doing them one-two at a time. I really want more feedback from what is out there, but if you really want one I can do one.
Post by jahlive12 on Feb 17, 2015 20:39:49 GMT -5
I want one Wesk but not in a rush before summer. So do you think you will get enough feedback before say May-July ?
Post by wesk on Feb 18, 2015 14:52:50 GMT -5
I doubt I will ever call it "enough," so when you want one I will get you one.
Post by svojohn on Feb 20, 2015 2:03:23 GMT -5
What kind of feedback are you looking for Wes? The one I received from you still works great!
PS: yes it's on a running engine and NOT sitting on a shelf or on jack stands.
Post by wesk on Feb 20, 2015 10:09:38 GMT -5
John, that's kinda what I am looking for. How does that car run in general? Fastest engine speed it has turned to this point?
Post by svojohn on Feb 21, 2015 2:03:59 GMT -5
The engine runs smooth and felt very linear from the drivers seat. The owner of the car loves it and has yet to say anything negative. The engine peaked out around 6500 RPM and the limiter comes on at 6800 RPM.
I have another car here and the owner told me he ordered the 16-1 CAS from you. Hopefully I'll have this up and running in the next few months.
Post by cupton79 on Feb 21, 2015 6:12:58 GMT -5
I am interested in this... PM sent
Post by Carl on Feb 21, 2015 10:34:43 GMT -5
Wes, I showed interest in this before and I am still. Do you have kits already made up or is it a "made to order" thing? If the latter, what's the lead time to receive one?
