Post by bleavitt23 on Nov 25, 2014 1:33:39 GMT -5
I bought a second-hand Wilson MS2x with an LS coil setup. I tried a test fire tonight and it doesn't not appear to be getting any spark. I'm basing this information on the fact that I get nothing on my timing light on any of the plug wires. I installed the cam sensor and made the TFI wiring change as per instructions, double and triple checked the wiring between the MS and coils. The coils have power with the key on, and they have a good ground. Everything else appears to be OK so far, with the setup. I don't know if this is normal or not, or related, but I also do not get any movement of the tach during cranking. I can get it to move using the I/O Output test mode, though. Any ideas on where to start looking?
Thanks, B
Post by Stinger on Nov 25, 2014 23:34:08 GMT -5
If the engine ran before and your wiring is correct, and the tune is something that works on some engine them the ecu is probably bad.
Post by bleavitt23 on Nov 26, 2014 0:00:37 GMT -5
Thanks, Stinger - I have this posted over on TF as well. The wiring setup has been called into question. I hope that's the issue, but I followed the only directions that Scott has on his site. I have an Email in to Scott as well. He's been pretty responsive in the past, so hopefully I missed something...
