Post by Stinger on Jun 16, 2015 12:59:04 GMT -5
Electronic Boost Control Solenoid (Pierburg)Intended to be used with our PiMP ECU to allow the ECU to control peak boost and also how quickly boost ramps up to peak to control wheelspin. Plugs directly into the stock boost control solenoid harness on factory 2.3T vehicles. For those with non-factory turbo cars, this solenoid uses a standard EV1 injector connector which is easy to find and integrate into your harness. Can be used with other ECU's that can control a boost solenoid as well. Install instructions on the PiMP support forum. Price: $ 30.00 Shipped with other ordered items, $35 Purchased individuallywww.stinger-performance.com/universalparts.html
Post by crashman on Mar 7, 2016 0:47:14 GMT -5
Can your electronic boost control solenoid be used as a replacement for the factory boost control in a 1986 svo with the factory ecu?
Post by Stinger on Mar 7, 2016 2:40:46 GMT -5
No
Post by funiwant on Sept 24, 2016 15:31:29 GMT -5
which ports go where, I have searched and can't find a diagram for which port goes where.
Post by Stinger on Sept 24, 2016 22:21:45 GMT -5
The FAQ thread in both PiMP and PiMPx sections have the diagram for how to hook them up.
Post by funiwant on Sept 25, 2016 12:02:43 GMT -5
Thanks. When I used the "search" function, I entered all words and even in different combos and it never brought up the FAQ section. Maybe the wording in the opening post should say something like: "Install instructions on the PiMP FAQ section of the support forum". Just a suggestion. Thanks again. But then again if anybody reads this again, they will know where to find it.
