gman
Boosting 10 psi
Post by gman on Jan 13, 2016 8:26:33 GMT -5
Good point. I'll replace the PIP first and see if the problem goes away. If not, then I'll do the ICM.
gman
Boosting 10 psi
Post by gman on Jan 15, 2016 15:04:34 GMT -5
Well, this just shows that you have to believe your indications:
Post by Stinger on Jan 15, 2016 15:43:37 GMT -5
Yeah, that will do it.
So is the gear moving on the shaft (sheared pin) or is the slop coming from somewhere else?
gman
Boosting 10 psi
Post by gman on Jan 15, 2016 18:20:26 GMT -5
The gear is fine -- roll pin still in place. The weld, or whatever attaches the vane mounting plate to the shaft at the top, has failed, likely due to nearly 30 years of galvanic corrosion (dissimilar metals in contact). I get a couple of degrees of free play, as you saw in the video. Had I not yanked the dizzy and started to take it apart, I would have never found this problem. I did notice that the timing bounced around a bit when I set it. Now I know why. This has been one of the more tricky problems I've ever encountered.
I'm getting a reman, and keeping my Motorcraft TFI. Thanks for listening!
