Post by turbdo88 on Mar 28, 2016 18:23:15 GMT -5
Hi can someone please give me model number for walbro 255 lph fuel pump. I am ordering from Amazon and not sure exactly the one . do I want HP also .. Thanks
Post by turbdo88 on Mar 28, 2016 18:26:30 GMT -5
It's a 1988 t bird basically stock with big exaust and boost valve
Post by turbdo88 on Mar 28, 2016 19:04:03 GMT -5
Also I was looking at a speed unlimited/kirban 5005 billet aluminum adj for on Amazon. It is a good upgrade and will fit directly to stock rail . and can be used if I upgrade rail with one on this site ??
Post by Stinger on Mar 28, 2016 20:00:55 GMT -5
Post by turbdo88 on Apr 1, 2016 20:39:08 GMT -5
OK I just ordered the pump and for from there
fuel pump
Apr 4, 2016 11:50:58 GMT -5
via mobile
Post by turbdo88 on Apr 4, 2016 11:50:58 GMT -5
Just wondering how do I set adjustable afp regulator up when I install is there a basic set point for stock vehicle to start wit or do I need to go of afr readings from wideband Thanks
Post by Stinger on Apr 4, 2016 13:00:02 GMT -5
Set it to stock (39psi with the vacuum line pulled from the FPR) and adjust from there if the AFR at WOT isn't where you want it. Fuel pressure makes "global" changes though (meaning it adds or removes fuel to the engine under all conditions, not just WOT) so you have to make compromises with the stock ECU like allowing it to be "too rich" at boost onset so it's still safe at redline.
fuel pump
Apr 10, 2016 17:28:46 GMT -5
via mobile
Post by turbdo88 on Apr 10, 2016 17:28:46 GMT -5
And basically that is at 10.5 on turbo coupe correct cause that were mine always was before problems started from tail pipe touching fuel tank and boiling fuel on way to colorado. So I'll put new walbro pump in and get the fuel presure at full boost before putting kirban fpr in. I don't want to band aid it. It runs leaner since that trip. Its fifteen roughly at idle and 11.5 twelve at wot.
Post by Stinger on Apr 10, 2016 19:06:36 GMT -5
11.5 is "ideal" but 12.0 is probably OK at stockish boost levels. It should be 14.7ish at idle/cruise.
fuel pump
Apr 11, 2016 0:06:29 GMT -5
via mobile
Post by turbdo88 on Apr 11, 2016 0:06:29 GMT -5
When u sat stockfish boost levels. I am running 18 psiwith boost valve. K.n. filter and three inch exaust is that still ideal wit these mods ?
Post by Stinger on Apr 11, 2016 2:06:47 GMT -5
Mid to high 11's should be fine.
fuel pump
Apr 11, 2016 16:09:00 GMT -5
via mobile
Post by turbdo88 on Apr 11, 2016 16:09:00 GMT -5
Thank you
fuel pump
Apr 19, 2016 1:30:43 GMT -5
via mobile
Post by turbdo88 on Apr 19, 2016 1:30:43 GMT -5
I put in the walbro 255 high pressure pump . pinging seems to be gone and I am pretty sure I am at 11 .3 or so at wide open throttle. So far so good .I have the kirban fpr but will wait to put in after 100% sure isues are fixed with air fuel rstio. Haven't really driven far cause car isn't insured yet .
Post by Stinger on Apr 19, 2016 11:26:26 GMT -5
Nice!
Post by tbird86 on Mar 13, 2019 11:50:06 GMT -5
Will the walbro GSS340 fit fox body mustang as well as the in tank turbo coupes? I have 2 to upgrade.
