Post by merk23literturbo on Aug 29, 2016 17:53:41 GMT -5
I installed a Bamafuel after the MAP was replaced and tuner was tested to be good. My issue is a dropout while running. I'm attaching the datalog and the tune. I am thinking it's related to wiring at the TFI and it's harness but just want someone to check me out to make sure I didn't miss something stupid. The fuel pump primes with the key on when I touch the Remote mounted TFI. Thanks Attachment DeletedAttachment Deleted
Post by Stinger on Aug 30, 2016 0:51:27 GMT -5
Have you tried comparing a log of it dropping out while driving and also while messing with the TFI wiring to see if they look the same in the log? The bottom line is we know it shouldn't have issues when you mess with the TFI wiring so you've got to start there, fix that, and see if the problem persists.
Post by merk23literturbo on Aug 30, 2016 8:59:35 GMT -5
Yeah, that's on today's list, I just wanted someone to look at it because it's been so long since I used the Bamafuel and there was a ton of software things I had to do to get everything working. Thanks for looking at it.
Post by merk23literturbo on Sept 6, 2016 12:09:07 GMT -5
OK, I cleaned and tightened the crimps on the remote TFI wiring and it doesn't drop out as often. I think the remote wiring is the problem, I will eliminate it and put the TFI back on the dizzy and see if the drops go away completely. One question, while looking at the log when I see a drop it shows up as one spike and the engine sec value shows 1. However, sometimes I see a longer drop out time wise and the value always shows 33. I read up on the value that is assigned to it, 1 = engine not running, et cetera. What does the 33 mean?
Post by Stinger on Sept 6, 2016 20:38:15 GMT -5
Where is this "engine sec value" you're looking at?
Post by merk23literturbo on Sept 7, 2016 15:23:52 GMT -5
In the datalog, Its just listed as engine.
Post by Stinger on Sept 7, 2016 19:52:24 GMT -5
That value depends on the firmware version you're running, and is the sum of multiple numbers.
