Post by dsrace on Dec 11, 2016 19:26:09 GMT -5
Post by 1989merkur on Jan 1, 2017 19:18:52 GMT -5
Are you looking for a Merkur style bracket? It has a power steering pump bracket with the alternator above it and mounts on left side of engine
Post by dsrace on Jan 19, 2017 8:13:09 GMT -5
yep the factory bracket on the t bird mounted on the drivers side wand carried the power steering pump and alternator mounted on top. not sure if the merkur was the same
Post by karl on May 2, 2017 10:16:08 GMT -5
still have the pass alt mount?
Post by dsrace on May 2, 2017 21:32:52 GMT -5
yes but not in my hands right now. i should have it back in a week i believe. a buddy is copying it to make 3 billet brackets.
Post by dsrace on May 2, 2017 21:33:36 GMT -5
i was going to see if i could trade it for a stock drivers side mount but i have already made the swap so i'll just sell it. if he does get them built and anodized as he should then i'll sell the stock one i have bolted on right now as well.
Post by karl on May 3, 2017 0:02:31 GMT -5
No worries, just let me know when. Not a rush, kinda collecting some stuff to see if I can make it work for my application.
Post by dsrace on May 3, 2017 22:45:23 GMT -5
sounds good i'll pm you when i get it back. that one will need a tensioner as you can see in the pic. if your building the engine or are going to replace the water pump, then would be a good idea. i really don't know if there different but one could look them up and see if the p/n# is diff. they looked the same to me but did not measure them. other wise just the pulleys and have to have that keyed hub for the crank.
Post by karl on May 4, 2017 9:27:16 GMT -5
other wise just the pulleys and have to have that keyed hub for the crank. wouldn't happen to have an extra set of these also?
Post by dsrace on May 4, 2017 16:49:52 GMT -5
no i don`t....i have seen that hub on ebay a few times but pretty rare. most places sell them with the engines or cranks. might even check old stock on rock auto
