New Product: Configurable Gauge for MS2/MS3 based ECU's
Mar 22, 2017 19:56:53 GMT -5
one2fast4u likes this
Post by Stinger on Mar 22, 2017 19:56:53 GMT -5
All-In-One Configurable Gauge for PiMP/PiMPx/PiMPxs/Microsquirt/MS2/MS3
The gauge is compatible with all the Megasquirt ECU except the Megasquirt 1. The billet anodized aluminum enclosure and the real carbon face plate give an incredible look. The color OLED display allows to display more information than a standard gauge and the colors are configurable. You can replace an entire dash full of gauges with this single gauge. Actually there are 7 different screens and others will come. 24x multicolor LED gives a quick way to see what's happening. The screen brightness and LEDs adjust itself automatically with the luminosity sensor.
One of the biggest features is the alarm module which is very powerful and flexible. It allows to monitor each input and notify when there is something abnormal.
There are two buttons on the gauge to change the displayed screen and change basic settings. Advanced configuration of the alarms are made through a webpage with a built-in Wi-Fi connection to a smart phone, tablet or laptop.
Check out this video showing us cycling through some of the features:
Display Data:
Available data to display on the gauge with MS2 based products (PiMP, Microsquirt):
-MAP (Manifold Air Pressure)
-RPM
-CLT (Coolant temperature)
-TPS
-IAT or MAT (Intake Air temperature)
-Ignition timing
-AFR1 and 2
-AFR Target
-EGO Correction
-EGT1
-Battery voltage
-Generic Sensor 1 and 2
-VSS (Vehicle speed)
For the MS3 based products (PiMPx/PiMPxs), you can display all the above plus:
-MAF (Mass air flow)
-Gear
-Injector timing
-Cam IN and EX positions
-ECU error code
-Fuel Pressure
-Oil temperature
-Oil pressure
-Speed sensors of each wheel
-And much, much more!
Analog Expansion:
The gauge can also be connected to up to 3 sensors with the 3x 0-5v analog inputs and can be used as an expansion board. This means that if there is a sensor connected to the gauge, the ECU can read it over CANBus and display it in TunerStudio and datalog the value.
Alarm Examples:
-Abnormal temperature (oil, coolant, EGT and more).
-Abnormal pressure (oil, boost, radiator and more).
-Air fuel mixture too lean or rich based on specified conditions.
Features:
-Full color 1,7" screen with 160x128 resolution
-24 full-color LEDs
-2 buttons
-3x protected 0-5v analog inputs
-Display battery voltage
-1x Digital input
-1x Digital output
-CANBus communications
-Over 16 configurable alarms
-Configurable with any Wi-Fi equipped devices like smart phones, tablets or laptops. No app needed!
-Auto dimming feature
-Interchangeable carbon faceplate
-8-18v compatible
Optional Compatible sensors (maximum 3 per gauge):
-Any air fuel controller including our Spartan 2 Wideband Controller.
-Temperature sensors for oil, air, coolant and more.
-Pressure sensor for oil, fuel, coolant and more
-MAP sensor up to 44 PSI of boost!
-Exhaust gas temperature (EGT) 1250 Celsius (2200F)
-Flex fuel (coming soon)
Dimensions:
Compatible with any standard 52mm (2 1/16") gauge pod.
Overall dimension is 69mm Diameter and 20mm thick!
Includes:
-Gauge w/5' wires
-Mounting Bracket
-One year warranty
-Free lifetime technical support
Instructions & Documentation:
-User Manual: Click Here
Price: $ 275.00
Display Data:
-RPM
-TPS
-Ignition timing
-AFR1 and 2
-AFR Target
-EGO Correction
-EGT1
-Battery voltage
-Gear
-Injector timing
-ECU error code
-Fuel Pressure
-Oil temperature
-Oil pressure
Analog Expansion:
Alarm Examples:
Features:
-24 full-color LEDs
-2 buttons
-1x Digital input
-1x Digital output
-8-18v compatible
Dimensions:
Includes:
-Gauge w/5' wires
-Mounting Bracket
-One year warranty
Price: $ 275.00
