Post by pete1977 on Jun 5, 2017 9:22:23 GMT -5
92 ranger 2.3 to 2.3t swap, followed your wiring. Truck has spark and 38 psi fuel pressure at rail.Tried to start the other day, just cranks will not start. I haven't installed the vam, but it will not run in limp mode. Any help would be greatly appreciated,thanks.
Post by Stinger on Jun 5, 2017 12:15:24 GMT -5
Install VAM, report back.
Post by pete1977 on Jun 5, 2017 12:38:50 GMT -5
It should at leat start without vam and run in limp mode.
Post by Stinger on Jun 5, 2017 23:09:58 GMT -5
If you say so...
From my experience (18 years or so with these engines), some run without the VAM, some don't. So I guess you can decide whether you trust my advice or would rather dispute my advice.
What I do know is that wasting time trying to figure out why an engine that's missing it's most important sensor (actually two sensors since the VAT is built into the VAM) won't run is always going to be a waste of time. First step in diagnosis is fixing known problems. In this case, the known problem is that the most important sensor is missing. So my advice is to install the VAM and figure out whether you have a real problem (still won't run) or not.
Post by pete1977 on Jun 12, 2017 8:47:09 GMT -5
Installed vam that came from the same car as the engine. Still just cranks and won't start.
Post by Stinger on Jun 12, 2017 13:54:16 GMT -5
Does it have spark?
Does it have fuel pressure?
Are the injectors pulsing?
What are the codes?
Post by pete1977 on Jun 12, 2017 13:57:49 GMT -5
Yes it does have spark and 28 psi at the rail. I do not know if injectors are pulsing, and I haven't tried to read the codes.
Post by pete1977 on Jun 12, 2017 14:03:54 GMT -5
Sorry 38 pai at the rail.
Post by Stinger on Jun 12, 2017 14:20:20 GMT -5
Check for injector pulse and scan codes. The codes will say if there are wiring issues, or if there is a sensor or ECU fault. EEC-IV Code readers are about $25, or you can use a paper clip and the check engine light and count the flashes.
Has the timing belt or distributor been loosened/moved since it last ran in the donor vehicle?
Post by pete1977 on Jun 12, 2017 14:24:58 GMT -5
I puled the dizzy to put a new pick in but have put #1 on tdc and pulled the cap, button points to #1.
Post by pete1977 on Jun 12, 2017 18:02:35 GMT -5
I pulled the following codes 58,65,66,81,82,84,85 from ecm.
Post by Stinger on Jun 12, 2017 18:17:16 GMT -5
You've got both VAF and VAT codes there (3 total codes) that all say the VAM is either faulty or mis-wired. Since it ran before, we can assume it's not faulty. The rest are typical "swap" codes.
I was going to link you to a site that has info regarding what the VAT and VAF signal should read but the site appears to be down at the moment so I can't find the exact link for that PDF file.
Post by pete1977 on Jun 12, 2017 19:21:16 GMT -5
I have reduced the codes to 58,81,82,83,84,85,88. I can hear the injectors click on key cycle but not when cranking.
Post by Stinger on Jun 12, 2017 19:45:15 GMT -5
What did you do to get rid of the two 60's codes?
58: Vane Air Temperature (VAT) sensor out of range or open 88: Electronic Ignition - IDM, DPI or spout circuit fault
VAT is the air temp sensor inside of the VAM so it's still got a wiring issue, or is faulty. It's easy to tell if the reference site that's currently not working was available.
Code 88 should indicate a no spark condition, or at least a lack of timing advance (though advance doesn't kick in until it's running).
Sounds like you need to verify that injectors are pulsing while cranking.
Post by pete1977 on Jun 12, 2017 20:36:03 GMT -5
I had pin 27 in 28,that took away the 60''s codes.
