Post by Stinger on Jun 13, 2017 1:03:05 GMT -5
Post by pete1977 on Jun 13, 2017 11:38:00 GMT -5
On the vam wiring does it go grn/purple from left to right or right to left? I have 5v on orange/white.
Post by pete1977 on Jun 13, 2017 11:52:55 GMT -5
The vam appears to be good as per the test you sent. Now I haven't touched cam timing, but I had the dizzy out to put a new pick up in. Engine wasn't cranked or moved while dizzy was out.
Post by Stinger on Jun 13, 2017 13:34:10 GMT -5
You should have 5v on the orange wire as that's the power wire for the sensor.
We've verified fuel pump, VAM/VAT, and spark.
So all you haven't confirmed is that the injectors are pulsing while cranking correct?
Post by pete1977 on Jun 13, 2017 13:40:09 GMT -5
They are not pulsing while cranking as best I can tell.
Post by pete1977 on Jun 13, 2017 13:42:18 GMT -5
With the key in the run position both wires on the injectors have 12v.
Post by Stinger on Jun 13, 2017 14:17:31 GMT -5
One wire is grounded to pulse the injectors. They pulse very quickly so you typically can't "see" the pulse with a multimeter or test light. What you can see though is a drop in voltage. What method are you using the check for a pulse?
Post by pete1977 on Jun 13, 2017 14:18:53 GMT -5
Multi meter.
Post by pete1977 on Jun 13, 2017 14:35:30 GMT -5
Voltage does drop on the white wireally when cranking.
Post by Stinger on Jun 13, 2017 15:51:09 GMT -5
If voltage drops then it's most likely pulsing. Cranking it and then pulling a plug to check for fuel on the plug would verify.
If you've got spark while cranking, fuel pulse and pressure while cranking, and obviously air while cranking and it's not even attempting to start (sputtering, popping, etc.) then there is a timing issue.
Post by pete1977 on Jun 29, 2017 18:49:43 GMT -5
Nothing has been touched on the timing except the dizzy. It was removed, engine wasn't turned and dizzy set back exactly where it came out. Belt is good as engine has 44k on it.
Post by pete1977 on Jun 29, 2017 19:16:21 GMT -5
I now have a code 88.
Post by Stinger on Jun 29, 2017 23:43:16 GMT -5
88-Electronic Ignition - IDM, DPI or spout circuit fault
Check voltage at the SPOUT wire while cranking.
Post by pete1977 on Jun 30, 2017 6:28:36 GMT -5
What should I have at the spout when cranking?
Post by Stinger on Jun 30, 2017 13:51:32 GMT -5
It should be north of 5v.
