mavereq
Microsquirt Premium
Post by mavereq on Jul 20, 2017 22:15:42 GMT -5
Ant you check your timing while cranking?
Post by Stinger on Jul 20, 2017 22:32:05 GMT -5
It should be 10 deg BTDC while cranking.
Post by pete1977 on Aug 2, 2017 18:56:57 GMT -5
What is note 2on your pinout on the wire from 15 to 27?
Post by Stinger on Aug 2, 2017 19:55:44 GMT -5
Remove pin and install @pin 27 (Note 2) --> Remove pin replace with pin moved from pin 15 (Note 2)
It just links the two pins together in text, nothing more.
Post by pete1977 on Aug 2, 2017 20:18:20 GMT -5
I still can't get it started. Injectors are not opening. Crank and all plugs are dry. I still have 38 psi at the rail. I have spark, it just won't start.
Post by pete1977 on Aug 2, 2017 20:56:15 GMT -5
My injectors are not pulsing. I used the Ranger injector harness and tbird rail and injectors. The red and green wires stay 12v + during cranking.
Post by Stinger on Aug 2, 2017 22:44:18 GMT -5
What are you using to measure injector voltage while cranking? A noid light is the only accurate way to measure it because otherwise the pulse is so quick it's not caught by a multimeter.
Post by pete1977 on Aug 3, 2017 7:54:49 GMT -5
Led test light.
Post by Stinger on Aug 3, 2017 12:33:31 GMT -5
Scan for codes
Post by pete1977 on Aug 3, 2017 12:58:33 GMT -5
81,82,83,84,85
Post by Stinger on Aug 3, 2017 13:27:11 GMT -5
You gotta start tracing the signal from the distributor to the ECU and then out of the ECU to the injectors then and find where the "pulse" signal stops.
Post by pete1977 on Aug 15, 2017 21:25:59 GMT -5
I have found with koeo throttle closed I have 4.9v at tps. This will tell injectors to close, am I correct? Voltage should be less than 3.7 closed throttle?
Post by Stinger on Aug 15, 2017 22:14:06 GMT -5
Yes, that puts it in flood clear mode which shuts off the injectors completely. Fix TPS wiring and you'll be good to go.
Post by pete1977 on Sept 12, 2017 17:53:46 GMT -5
Fixed tps wiring still no injector pulse.I have checked continuity on pins 16,36,56. New tfi module, new pickup coil and still have code 81,82,83,84,85,88. I have spark and fuel pressure still. I invested in a snap on noid light, for it to tell the same thing I already knew. My injectors aren't opening.
Post by Stinger on Sept 12, 2017 23:25:27 GMT -5
So TPS voltage is now around 1v closed throttle?
Is this a known good ECU (you saw it run the donor engine)?
