Post by mustangnismo23 on Jun 5, 2017 21:55:38 GMT -5
Hi, I have a 2.5L turbo motor running Holley EFI. I am looking for some help with a base tune to autotune with. My setup is, closed chamber solid lifter head with a boport stage 3 cam, Holset HX35, 120 lb injectors, A1000 fuel pump, LS coils. AR103 spark plugs gapped to .028
I have attached my tune as well as a screen shot of my timing and target afr tables.
Thanks so much !
Post by Stinger on Jun 5, 2017 23:04:01 GMT -5
We don't mess with Holley ECU's so we can't really help with a base tune. You're sort of "on your own" with that system.
There are some sample Megasquirt tables in the FAQ in this section that you can use as a starting point or to compare with if you want.
Post by mustangnismo23 on Jun 6, 2017 8:11:47 GMT -5
Thanks for the reply Stinger. I'll check that timing table out. would that table be a good start for a closed chamber head ?
Thanks for all the help !
Post by Stinger on Jun 6, 2017 17:08:26 GMT -5
A closed chamber head should get you about half a point of compression so you'd need to adjust timing accordingly.
