Post by justboosted on Jul 18, 2017 12:51:14 GMT -5
Okay, I would like to be able to run 11.9s in my full weight SVO. Should I be able to do it with these mods?: Boport stage 4 head Boport 2.5 cam Ported intakes 3 inch exhaust all the way back Stinger header 80# injectors PiMP 255lph in tank Front mount intercooler HX35w Stock throttle body Strange adjustable shocks and struts Factory rated springs with a coil cut off I am running 22 psi on 93 octane Thanks for the feedback
Post by Stinger on Jul 18, 2017 15:36:57 GMT -5
I would think so as long as you've got some good tires like ET streets or similar (drag radials aren't ideal for a turbo 4 cyl unless it's got an auto trans).
