bymderek
Boosting 10 psi
ms2 experiments
Post by bymderek on Jul 19, 2017 1:40:03 GMT -5
Hey there, finally got the trashy project running... Setup: 2.3 turbo 20psi tops Well gotta start up tunnig but i will be using autotune. I really want to make this thing work properlly. I will be just around 240kpa limits and under 7k rpms Usually Ive manually tuned the megasquirts in the past and worked quite alright, but I do want this kinda perfect for daily and weekend racer for fun...
Any pointers would be appreciated.
Post by Stinger on Jul 19, 2017 15:10:30 GMT -5
Are you asking for what sort of AFR values to plug into the AFR target table?
If so you'll need to also state what cam you're running as that effects idle AFR (big cams won't idle at 14.7). If stock, 14.7 at idle/cruise, 11.5 at 20psi, 12.5 at 5-10psi, 13.5 at 1psi, you can taper between these values. 11.0 above 20psi.
bymderek
Boosting 10 psi
ms2 experiments
Post by bymderek on Jul 19, 2017 15:41:20 GMT -5
Are you asking for what sort of AFR values to plug into the AFR target table? If so you'll need to also state what cam you're running as that effects idle AFR (big cams won't idle at 14.7). If stock, 14.7 at idle/cruise, 11.5 at 20psi, 12.5 at 5-10psi, 13.5 at 1psi, you can taper between these values. 11.0 above 20psi. Ranger 95 roller cam, so stock works
Post by Stinger on Jul 19, 2017 18:56:01 GMT -5
OK, so the above info should be what you're looking for then.
