Post by mustangnismo23 on Aug 10, 2017 11:03:21 GMT -5
Hi, currently my fuel/ignition table ends at 7k rpm. I want to rescale my tables to go to 8k. My question is should the increments be even from 500 to 8k or should there be more resolution around the areas of drivability?
Thanks,
Post by Stinger on Aug 10, 2017 12:31:58 GMT -5
It uses the value from 7k if you exceed 7k so it's not required to re-scale to run more than 7k rpm.
You need more resolution at low rpm (where the engine transitions a lot with varying throttle, load, map, etc.) than you do at high rpm where you're basically only wide open throttle and fuel and spark requirements don't change much. So if you want to scale it, I'd suggest only spreading out the last few columns rather than scaling the whole table.
Post by mustangnismo23 on Aug 10, 2017 12:39:15 GMT -5
10-4, thank you so much !
