Post by mustangnismo23 on Nov 1, 2017 22:49:59 GMT -5
Hi guys, I was wondering if you have a timing map I could use for E85. I just started tuning with E85.
Thanks.
Post by Stinger on Nov 2, 2017 0:40:29 GMT -5
E85 doesn't really "want" much different timing than premium pump gas. It can tolerate quite a bit more but it is just harder on the engine without making significantly more power. So in general, take your pump gas map, add a degree or two, and use more boost as the power gainer, not timing.
Post by mustangnismo23 on Nov 2, 2017 9:40:30 GMT -5
10-4
Thanks again !!
