Code 28
Dec 9, 2017 21:22:14 GMT -5
via mobile
Post by turbdo88 on Dec 9, 2017 21:22:14 GMT -5
So I am still having slight missed and sometimes cars tumbled or surges like. Also have a slight pinging at full throttle boost. Today I ran codes and an now getting code 28. Any ideas of best way to trouble shoot this. I cleared codes and ran back to back and code 28 comes right back. First I get a one twice for system pass then code 28. Thanks in advance
Code 28
Dec 10, 2017 19:50:19 GMT -5
Post by Stinger on Dec 10, 2017 19:50:19 GMT -5
28-VAT out of range.
VAT is the temp sensor inside the VAM. It's not replaceable. I'd check wiring and if it's good then you need to replace the VAM to fix the VAT code.
Code 28
Dec 12, 2017 20:58:02 GMT -5
via mobile
Post by turbdo88 on Dec 12, 2017 20:58:02 GMT -5
So I found a broken vacuum line at vacuum tree. Seems to have fixed problem with this code. Driveover two hundred miles since fixed and no codes. Thanks
