Post by 414notch on Dec 19, 2017 16:53:24 GMT -5
I'm considering purchasing a pimpx ECU but had a few concerns. My setup is a 414w with 2 kits. I'm wanting to do away with the maf and do a speed density setup. The main reason is to run an accufab 4150 style throttle body. Is this possible? Will the GM style iac and TPS that come with the throttle body be compatible if I rewire the connectors? Tia
Post by Stinger on Dec 19, 2017 20:49:18 GMT -5
You'll need the PiMPxs not the PiMPx. The "xs" is the sequential version and Mustangs are sequential.
The PiMPxs can use the GM TPS and IAC so that's not a problem.
Post by 414notch on Dec 19, 2017 21:06:30 GMT -5
Awesome!! I look forward to doing business with you.
Post by Stinger on Dec 20, 2017 1:31:37 GMT -5
Thanks for your interest.
