Post by justin7t on Dec 27, 2017 15:11:19 GMT -5
Motor has pimpx,ported head,cam, upgrade turbo, exhaust. My 55lb gave out of me a while back.. I want a 80lb set from this website the flow chart/deadtime wont open, can I please have injector deadtime specs for fid 850 and 80lb siemens.. Will I notice a difference between the two ??
Post by Stinger on Dec 27, 2017 17:41:36 GMT -5
FID850 dead time at 13.2v and 43psi is .968ms. 80lb Siemens under the same conditions is about .7ms.
The main difference between the two besides them being different designs is that the FID's are flow matched to within 1% while the Siemens are a "production" injector which means they can vary up to 3%.
Post by justin7t on Jan 1, 2018 16:50:13 GMT -5
I have placed my order, going to set my required fuel at Engine and Sequential Settings, jump jp1,jp14. My questions are after I set dead time do i also punch in the numbers for voltage curve I found the data on here on there curve and second I dont understand what to set on 2 squirts/cycle alternating or 1 simultaneous Instructions give me 2 choices will it run the same either or ?
Post by Stinger on Jan 2, 2018 0:40:51 GMT -5
You should enter all the injector data you have available to you.
You can do either one as stated, do 2 alternating.
