boostx316
Boosting 10 psi
1989 notch 88 2.3 turbo swap project
Post by boostx316 on Mar 29, 2018 14:17:57 GMT -5
Will pump work with a a4ld or c4 the a4ld is already in the car with the 88 2.3t swap
Post by Stinger on Mar 29, 2018 14:55:40 GMT -5
C4 is not computer controlled so that certainly works. A4LD is "barely" computer controlled, only converter lockup needs to be dealt with. Easiest thing there is to just put it on a manual switch so you can lock it up on the highway. You could also use a programmable output in the ECU to control lockup.
boostx316
Boosting 10 psi
Post by boostx316 on Mar 29, 2018 19:57:06 GMT -5
Thanks for your help what pump should i run all the wiring has already been done for the swap to work is that a problem?
boostx316
Boosting 10 psi
Post by boostx316 on Mar 29, 2018 20:11:20 GMT -5
Pimp^
boostx316
Boosting 10 psi
Post by boostx316 on Mar 29, 2018 21:03:56 GMT -5
When I do order a pimp witch one do I pick in the order section where it says pick 2.3 2.3t mustang or the 2.3 2.3t swap witch one should I click
Post by Stinger on Mar 29, 2018 23:26:37 GMT -5
PiMPx, 2.3T Mustang, also need a Spartan 2 if you don't have a wideband.
boostx316
Boosting 10 psi
Post by boostx316 on Mar 30, 2018 7:32:33 GMT -5
Thanks again for all your help I do have a AEM wide band that just came in my hy35 should be here today along with some parts I ordered from you. Once I get it up and running i will most likely be ordering the pimpx! Thanks again
