Post by 88turbobird on Apr 1, 2018 19:31:44 GMT -5
Just as the title says; what’s the thread size on the oil return line on the 88 turbo coupe? Going to replace it with a fitting that utilizes a hose barb on one end for my new turbo set up. Thanks!
Post by Stinger on Apr 1, 2018 19:46:57 GMT -5
The block fitting into the block is npt/pipe thread.
Post by 88turbobird on Apr 1, 2018 20:14:57 GMT -5
The block fitting into the block is npt/pipe thread. What about the oil return line? I’ve heard 1/2” npt but I haven’t confirmed that. I’ll probably leave the block fitting in
Post by Stinger on Apr 1, 2018 20:50:49 GMT -5
If you leave the block fitting in then the thread on that is some sort of compression fitting that's way harder to find. Nearly impossible to find a compression to barb fitting in that size.
