xsaylr
Boosting 15 psi
Post by xsaylr on May 23, 2018 20:57:55 GMT -5
Stinger you gave me some good troubleshooting steps, and sure enough the wastegate actuator rod is disconnected. It's a little tough to get to, is there some trick to slipping it back onto the wastegate flapper arm? It's just short of reaching it. I tried a small slotted screwdriver through the hole in the rod for leverage, comes close but I just haven't haven't had any luck
Post by Stinger on May 24, 2018 1:54:23 GMT -5
Loosen the bolts on the bracket that holds it to the compressor housing. That should give you the added length needed.
xsaylr
Boosting 15 psi
Post by xsaylr on May 24, 2018 12:24:34 GMT -5
OK thanks, and is it just a small C-clip that's missing there? Be my guess
Post by Stinger on May 24, 2018 15:02:09 GMT -5
Yes, but the c clip sucks so it's better to use something that doesn't go flying every time you remove it. I use alligator clips. Other clips work as well, just make sure they fit into the groove.
