Post by Hueneme805 on Jul 27, 2018 15:28:08 GMT -5
Can’t seem to figure this short any help?
Post by Stinger on Jul 27, 2018 23:57:09 GMT -5
If it always blows the fuse immediately (so the short isn't intermittent) then it should just be a matter of spending time checking the ohms of every wire on the circuit. I don't know how the door switches and such you mentioned should act since I don't have one here to test.
Post by Hueneme805 on Jul 28, 2018 18:00:28 GMT -5
The test shows that fuse #8 15amp is causing the short. I say that because when removing fuse#8 ohms drop compare to others. #8 fuse is for clock, key warning, Trip reminder, illuminated entry, keyless entry, power door lock release, interactive, power outside mirrors, what is the dams, clustering memory. I’ve checked wires and harness for loose or cut wires rubbing only on ones i can locate. Since I don’t have a manual I could only look at clock, outside mirrors. Need help locating the other items listed for fuse #8. Any suggestions on were to find locations.
Post by Stinger on Jul 28, 2018 23:05:11 GMT -5
You may hit up NATO to see if anyone has a manual for a TC, or have had a similar issue.
