Post by andyctgt on Jul 23, 2018 15:05:02 GMT -5
I have a mega squirt 2.3 t in a fox ive been playing with for a while and its finally running pretty good. so lately i have been playing with the launch control parameters to try to get it to build boost but no luck .anyone have any suggestions? Ive retarded timing added fuel and cut spark. Still doesnt want to make any boost
Post by Stinger on Jul 23, 2018 16:03:42 GMT -5
Does it not do anything at all (like it's not even turning on) or does it just not build boost?
Cut X from Y: Start with cut 5 from 7. Always cut an odd from an odd. If it will not hold your target rpm, go up on number (7 from 9 would be next).
Post by andyctgt on Jul 23, 2018 16:07:27 GMT -5
Ya its functioning properly just not building boost . i will give that a try thank you
Post by andyctgt on Feb 3, 2019 13:19:16 GMT -5
so im trying 4500 rpm, enable tps above 10% and cutting spark at 5 and 7. not sure where a safe place to start with retard to (deg)is. ive had it at 0 and when its holding at 4500 rpm it almost comes up to boost. should i up the rpm or take more timing?
Post by Stinger on Feb 3, 2019 13:25:40 GMT -5
You can't go below base timing with TFI so setting it to zero is still getting you 10 deg. Going farther won't change anything.
My reply above from July 23rd said what would be next to try.
You can try more RPM as well if you want, that's normally enough but if you've got a big turbo it may not be.
Post by andyctgt on Feb 3, 2019 13:29:43 GMT -5
i tryed 7 and 9 ill try more rpm thankyou
Post by andyctgt on Feb 3, 2019 13:50:59 GMT -5
Post by Stinger on Feb 3, 2019 14:13:24 GMT -5
Even a simple fuel cut with no spark cut will build boost without much issue so it shouldn't be this difficult. I'd suspect there are problems elsewhere, I'm just not sure what problems would cause this issue.
Post by Andyctg on Feb 3, 2019 18:15:55 GMT -5
I got it to make 118 kpa so that's a start thanks for the info.
Post by Stinger on Feb 3, 2019 19:59:06 GMT -5
How long are you staying in it once it's activated and at the rpm target?
Post by Andyctg on Feb 4, 2019 17:00:10 GMT -5
Only about 5 seconds when I changed it to 7 and 9 the rpm creeps up slowly. I've been playing with the settings and dont want to hold it to long if it's not the proper setup. I dont really need to use launch control I'm just trying to learn how to use althe features of ms.
Post by Stinger on Feb 5, 2019 2:49:10 GMT -5
Got it
