Post by kuhwazy on Aug 16, 2018 1:21:52 GMT -5
HI, I finally got my stinger ecu working correctly. I was just wondering how much boost I can run on a stock turbocoupe motor with a hx35 , big front mount intercooler on 60lb injectors without headstuds? I guess what Im trying to actually saw is when should I be putting some headstuds in this thing? BTW this swap is in a 86 chevette
Post by Stinger on Aug 16, 2018 1:41:43 GMT -5
There isn't any evidence that studs are better than stock bolts if torqued correctly for the style of bolt and that they are re-torqued after a head cycle. Note the stock 12 point bolts are a traditional bolt that gets torqued to 80-90 ft/lb in a few steps. The newer 6 point replacement bolts are TTY bolts so they are torqued to an angle, not a torque value.
How much boost you can run depends on fuel octane, intercooler efficiency, and the quality of the tune. A typical intercooled 91 octane setup is good for 20-21psi or so. 93 octane may get you to 23-24psi.
Post by kuhwazy on Aug 16, 2018 17:56:18 GMT -5
Ok thanks a lot man thanks for all the help
Post by dsrace on Aug 24, 2018 13:54:15 GMT -5
There isn't any evidence that studs are better than stock bolts if torqued correctly for the style of bolt and that they are re-torqued after a head cycle. Note the stock 12 point bolts are a traditional bolt that gets torqued to 80-90 ft/lb in a few steps. The newer 6 point replacement bolts are TTY bolts so they are torqued to an angle, not a torque value. How much boost you can run depends on fuel octane, intercooler efficiency, and the quality of the tune. A typical intercooled 91 octane setup is good for 20-21psi or so. 93 octane may get you to 23-24psi. i never would've guessed one could push 20 psi on 91 octane. learn something every day.
