Post by turborockkrawler on Mar 5, 2019 15:13:09 GMT -5
2.3 High Flow Fuel Rail with Factory Style Pressure Regulator Adapter Block Option from stinger ? thank you
Post by Stinger on Mar 6, 2019 0:20:31 GMT -5
Here is one of it mounted to a lower intake. I would not suggest hard mounting the FPR adapter to the rail like this though, it needs a piece of hose between them and the FPR mounted elsewhere (to the intake, head, firewall, etc.).
Post by turborockkrawler on Mar 6, 2019 10:09:30 GMT -5
do have the fitting sizes
Post by Stinger on Mar 6, 2019 13:30:06 GMT -5
Those are linked to in the listing on the site where the part is purchased.
Post by turborockkrawler on Mar 7, 2019 15:20:31 GMT -5
thanks
Post by 88turbobird on Mar 16, 2019 18:24:28 GMT -5
Post by Stinger on Mar 16, 2019 20:20:55 GMT -5
The chamfer keeps the o-ring from squishing out when you tighten it down.
Post by 88turbobird on Mar 17, 2019 14:15:11 GMT -5
The chamfer keeps the o-ring from squishing out when you tighten it down. Thank you. Don’t mean to hijack this thread but I bought the fuel rail to go along with my new Delphi injectors. Do the o-rings on the injectors need to be lubricated upon installation?
Post by Stinger on Mar 17, 2019 14:22:25 GMT -5
Injector o-rings always need to be lubed before assembly regardless of brand, rail being used, etc.
Post by 88turbobird on Mar 17, 2019 14:36:36 GMT -5
Injector o-rings always need to be lubed before assembly regardless of brand, rail being used, etc. And what would you recommend to use?
Post by Stinger on Mar 17, 2019 17:09:12 GMT -5
WD-40, light grease, motor oil.
Post by 88turbobird on Mar 17, 2019 18:23:21 GMT -5
Going to keep the questions rolling here; is the 1/8 npt port too small for a return line? I’m thinking of several different possibilities to route the fuel lines as space is always a problem
Post by Stinger on Mar 17, 2019 18:46:08 GMT -5
Yes, it's too small.
There is a spare return port on the rail that's labeled in the picture above.
Post by alpine615 on Mar 20, 2019 21:46:53 GMT -5
I have the billet fuel rail as well, and I'm finally getting around to purchasing the hose and fittings. I'm confused because the diagram posted above says 3/4-16 thread for the rail end fittings... and I thought that was the thread size/pitch for -8AN straight, but I bought two of these ( www.summitracing.com/parts/sum-220167b) and they are too small for the rail. Do you have a part number for a fitting that will work?
Post by Stinger on Mar 20, 2019 23:03:58 GMT -5
You sure they sent the right fittings?
Measure the thread diameter. -8AN is 3/4" and -10AN is 7/8".
