Post by turbo89ford on Nov 26, 2009 13:32:31 GMT -5
Hi, you guys are the only ones who know what these car are really worth what do you think my car is worth...
1989 Ford Mustang
2.3L Turbocharged- T5 trans 5 speed manual 24 mpg Professional paint done last year Turbonetics turbocharger t3/t4 hybrid with Ballbearing turbo w/ external evoultion wastegate bosch BOV valve and turbonetics manual boost control 25lbs of boost on race fuel 110 octane ( can be tuned for 93 octane with less boost) Tuned by Alternative Performance F.A.S.T fuel management 55lb. fuel injectors, 255 fuel pump 3" exhaust that split to dual 2 1/2" stainless tailpipes made by Diamond Fabricators Front mount intercooler 8.8 rearend with eaton posi unit and 31 spline moser axles upper/lower UPR control arms ported cast iron head with BIG valves dual springs and rollor cam forged rotating assembly Diamond Pistons new centerforce dual friction clutch MSD box 6A with MSD wires strange adjustables front and rear 2001 Mustang GT 17" wheels with kell tires up front and Nitto Drag Radials in rear.
Post by turbo89ford on Nov 26, 2009 13:35:24 GMT -5
here is the car
Post by sleepinsol on Nov 26, 2009 18:56:45 GMT -5
more pics would help with the appraisal.
Post by turbo89ford on Nov 26, 2009 18:58:08 GMT -5
picture of stock interior in good shape
Post by Stinger on Nov 27, 2009 23:51:45 GMT -5
Any hp or 1/4 mile performance numbers? Pics of engine?
Post by denz on Nov 28, 2009 1:05:20 GMT -5
ya more pics would help. so far so good.
Post by denz on Nov 28, 2009 1:07:48 GMT -5
what roller cam,
Post by turbo89ford on Nov 29, 2009 19:17:07 GMT -5
heres pic of motor pipes are now powder coated black and engine bay has been cleaned up a bit...you can see the crank case evac. -12 lines meet up to the baffles in the valve cover and run to the canister in lower left corner. The car made 292rwhp and 375 torque to the wheels. Car ran 12.70s in 1/4 mile. with a stock ranger roller cam and non ported intakes and stock throttle body.
Post by Stinger on Nov 30, 2009 1:11:32 GMT -5
If you got lucky enough to find the right buyer, you could probably get 4000-4500. Since not many people are interested in completed 2.3 projects though, odds are you will struggle to get much over 2500-3000.
Post by oneowner88lx on Dec 11, 2009 22:46:37 GMT -5
Nice car. I'd hold on to it.
