Post by 88turbobird on Apr 1, 2019 10:28:42 GMT -5
Original game plan was to redo the entire fuel system with my trunk mounted fuel cell; however, do to time constraints, this project will have to wait until after ford nationals. In the meantime, I figured I would install the new Delphi 66lb/hr injectors for some more room to turn things up. I was maxing the stock injectors (88 TC) at 13 lbs of boost on my current setup. I did a search but couldn't find exactly what I was looking for. My question are: 1) Are the Delphi injectors plug and play? - No Adapters? Anything to keep in mind during installation? 2) What is the true capability of the stock pump with these injectors? I've owned the car for three years and have no reason to believe the pump is anything other than stock. 3) Car is on a pimpx ecu; dead time should be the same (1.1) as stock but at 66 lb/hr, should I change to 2 squirts per cycle?
Thanks for the help!
Post by Stinger on Apr 1, 2019 12:43:52 GMT -5
Yes No idea, depends mostly on pump condition as it's certainly not "as new" anymore. 2 squirts alternating.
